07-03-2020, 08:13 PM
Porch light cover removal
Anyone knows how you're suppose to remove the lens cover off this porch light so as to replace the bulb? 2015 Winnebago Era; TIA.
07-04-2020, 12:55 AM
I don't have that model, but many porch light covers are friction-fit. Squeeze gently top and bottom and see if a pair of tabs come out of their slots...?
07-04-2020, 01:15 AM
Thanks for the suggestion; will try that tomorrow and see if that will work.
07-04-2020, 01:38 AM
Are you sure there's a bulb to replace?
"Il Travato Rosso"
2015 Travato 59g
07-04-2020, 03:47 PM
I have a 2017 Winne Trend and to replace my LED porch light, I had to pop the cover off to get to the mounting screws under the cover.
MLogan
Smyrna, TN
07-13-2020, 02:34 AM
Well according to my RV repair shop, they called Winnebago to get a replacement bulb for me to replace since I didn't want to keep messing with it and break it and Winnebago told them that it's a complete porch light assembly for the amount of $90 plus shipping. Needless to say I will be without a porch light for that price and especially not being able to just replace the LED bulb. RV repair shop said that they would see if they can replace with a different porch light where a bulb can be replaced...we will see.
07-13-2020, 06:06 PM
I figured as much. More and more, even for the home, light fixtures don't have bulbs and you chuck them when they fail. But they don't often fail. Have you checked with a voltmeter to make sure you're getting juice at the fixture when you turn on the switch?
"Il Travato Rosso"
2015 Travato 59g
07-13-2020, 06:27 PM
The porch light works but only 3 of the 8 round bulbs light up.
07-13-2020, 07:30 PM
I had the last edition of the Nissan 300 zx turbo with a similar top/center brake light. The price was ............... when part of it stopped working..... some of the led's.
But in an rv, it seems kinda simple? Someone drills a hole in the side for a light. Then sticks on whatever light they like. Don't like the light, pull off the old one and stick on a new and improved one.
07-14-2020, 02:55 PM
I had the same problem with the porch light on my Trend. Some of the LEDs burned out and I replaced it with the same light, received from fellow Trend owner when he replaced his porch light with a different light with sensor.
MLogan
2017 Trend
Smyrna, TN
07-15-2020, 09:32 PM
MLogan
2017 Trend
Smyrna, TN
How did you remove your porch light then?
08-05-2020, 03:52 PM
Porch light replacement
My porch light went down to only one bulb working, so I ordered a new one for $60 + $11 S&H. It has a foam gasket on the back where it would fit against the van body that has adhesive on it that sticks all around the edge of the cover in addition to hiding the location of the tabs that hold the cover on. Having "dissected" the new light to figure out how to remove the old one, I'm hoping for eventual good results.
08-05-2020, 06:05 PM
Thanks for the info and the photo. Can you provide me with the info on where you ordered the light so I can order one? Thanks.
08-05-2020, 09:55 PM
My local RV dealer ordered it from Winnebago. It is the complete replacement light.
It is Winnebago part number 184120-01-01A. You can see the part here: LUCIDITY but only sold in lots of 50! You might be able to order it directly from Winnebago Industries.
Once I got the old one out, I was able to disassemble it and see that the LED light bar is removable, however that would not have made the job any easier, imo. There is a sticker on the back of the light bar--photo attached.
My experience with this lamp replacement is that Winnebago has used lots of a caulk-like sealant plugging the screw holes and where the wires enter the van. You need a dental pick or something similar to remove the plugs to get to the screws and to tease out the wires. Once the wires are freed, there is plenty of working room. However, I doubt I'll ever want to do this again as there are probably easier and just as effective solutions to having an outside light. Aside from my time and inconvenience, the charge for the light was $60.00, and $11.59 for freight from Iowa to Minnesota. Good luck!
08-05-2020, 11:20 PM
Much obliged for the info. Will probably decide what to do when the last bulb burns out. You've been very helpful and appreciate you taking the time to provide me with all this info and pics.
