Originally Posted by RT-NY
I did check the voltage at the terminals marked "battery" on the fuse board of the PD4645 ("BATT" in pic below) -- is that what you mean by "voltage at the output of your PD"?
Maybe. Here we're mixing some 'theoretical' concepts with practical realities. On the theoretical side we speak of "the battery", "the charger", and, "the interconnecting wires, buss bars, lugs, studs etc."
On the practical side, it's hard to determine, precisely, were the 'charger stops', where the 'battery starts' - - everything between being the elusive connecting wires, the resistance of, and the voltage drop across, we're trying to measure.
Most power supplies/charges have a point (near the output terminal) that the internal wiring of the charger 'taps into' to measure its own output voltage. A power supply/charger often seeks to maintain a precise, predetermined voltage at this spot. If the loads/demands on the power supply/charger increase causing this voltage to drop, the internal circuitry will take corrective steps to force the voltage to return to that predetermined voltage. Ideally this is where one should measure the voltage output of the charger. We presume that the output terminals of the PD (which are marked "Battery") are as close as you're going to get to this "theoretical" measuring point.
If PD says that this voltage should be 14.4 volts, we would expect 14.4 volts. While, 14.05 volts seems close . . . it is a bit disturbing that you've lost nearly a half volt under a 37 amp load (did we remember that correctly?). One explanation could be that the "Battery" terminals are not the correct spot, that these exterior terminals on the chassis of the PD are actually connected to an internal 'output' through a set of wires that have resistance and are losing the .45 volts.
On the Battery side of things, about the best we can do is go directly to the plus and minus terminals (when making these measurements we should not assume that "minus" is equal to "ground" . . . go directly to the minus/ground terminal of both the PD and Battery when measure these voltages). But remember, even in a well designed battery, the terminal has finite resistance between the post/connection on the outside of the battery and the 'chemistry/plates' on the inside.
In case all this mumbo jumble has confused the issue. So to summarize, we're trying to determine why you're not getting the full 45 amps of charging. The possibilities are basically three: 1) the battery is already charged, it's output voltage is already "too close" to the 14.4 volt output of the PD, or, you could have a bad battery, but this possibility, we've been ignoring; 2) the PD is defective, poorly designed, it cannot output 45 amps; and/or 3) your connections between charger and battery are too high resistance, too much voltage is dropping across these connections. By way of an example, say the PD is properly outputting 14.4 volts, say further, that the battery voltage under charging conditions is 13.8 volts. Under this hypothetical example (but not too far from reality), there will be 0.6 volts (total, summed) across the two connecting wires. By Ohm's Law, this means that the maximum resistance of all your connecting wires, lugs etc can be 0.013 ohms. In view of our earlier discussion that your 12' of 8 gauge wire would have a resistance of 0.008 ohms - - which includes no allowance of the other 'interconnecting hardware' - - it is conceivable that you could exceed the maximum allowable resistance.
And it doesn't help that your PD is already down by a half volt. In measuring your battery and PD voltages again, we'd suggest also measuring the PD output with the battery disconnected.
