Old 10-29-2021, 06:29 PM   #21
Thanks for that info Booster.
Who would of though battery science could be so indepth
I'm not sure what tail amps are but i'll do my research. I just have a generic battery
monitor connected with a ground shunt which seems to be not too bad as far as reading current battery voltage and keeping track of consumption (Kw/h) . I just need to figure out how to convert that consumption to useful charge % left in my battery bank. (2 x 105 a/h lead acid Everstarts DC).
Sometimes i just revert to the old table of volts versus % remaining.
Thanks for your input on this.
ovsa is offline   Reply With Quote
Old 10-30-2021, 11:44 AM   #22
I have one just like this with a different brand name to it that has been working apparently well for a year. This is the 350 amp(500 surge) version. They have a 100 amp version for about $25 cheaper. Or you could get the fancy Victron one with the display and Bluetooth to the Victron phone app for $264.
https://www.amazon.ca/Voltmeter-Amme...%2C169&sr=8-10
Old 10-30-2021, 12:55 PM   #23
The devil is in the details with battery monitors in general and without seeing the complete instructions it is hard to know the details
There are certain features that are often missing in the some of the lower priced units like the very inexpensive amp hour counters that make them much less useful in real life and the description doesn't say if this unit has them or not.
Almost all show current amps and volts, use a totalizer for amp hours in/out, some show state of charge %, etc. The issue shows up with how they handle the amp hours in/out and the state of charger % as many take it as a straight math calculation of amps over time which will not be accurate over time because of the charge efficiency. It is much less of a problem with lithium as the charge efficiency is nearly 1.0, but is quite large on large on lead acid batteries.
Especially for lead acid, either AGM or wet cells, it is also nice to have a "fully charged" indicator that looks at the amps and volts to battery to determine when both are indicating a full battery. The volts must be at full absorption voltage and amps at the recommended tail amp setting. To be useful these need to be settable items to match your battery bank, size and recommended full charge recommendations. The indicator can be set for a lithium battery though when you figure out what settings to use for your system. The voltage climbs and amps drop very quickly as lithium get near full, so have to catch it where you want to be.
The defaults that Victron puts in the units now are so conservative they are pretty much useless for telling you if the batteries are really full, so the fully charged indicator comes on way early at maybe 85% or so, so they need to be reset to be accurate for fully charged. They appear to do that because most chargers on lead acid don't get the batteries totally full but will indicate they did. I think Victron got tired of telling people their chargers weren't capable of doing the charge accurately so give a matching false indication of full.
The above is why the PD chargers are good, as you can force the charger stages to get the batteries totally full, and indicated as such on the monitor with it set correctly, but it is a manual intervention based on watching the amps/volts to the batteries to see how close it is to the target tail amps/volts. Very few chargers allow you to do that, and doing it automatically in the charger is nearly non existent except for Magnum, maybe Outback, and probably a centralized controlled from the monitor Victron complete system.
Old 11-11-2021, 12:24 AM   #24
Is the LED charging indicator on the PD4645 suppose to flash when it's not plugged in to shore power?.
I though it was only when it was charging.
Mine has a one second flash all the time.
Thank you
03C170P
Old 11-11-2021, 03:35 AM   #25
eric1514's Avatar
Thank you
03C170P
Mine does. Not sure what it's trying to tell me, but every one I've owned has done it.
"Il Travato Rosso"
2015 Travato 59g
Old 11-11-2021, 04:40 PM   #26
just got a response back from PD :
"The light is on anytime you have shore power connected and/or the battery connected…this is normal operation
The Wizard and the light are powered by your battery when there is no shore or generator power. The power consumption is less than .012 amps."
That settles that.
