Old 02-27-2022, 12:52 AM   #1
Default Parasitic Drain on 48V 210ah Battery system
Hi guys
Just purchased a Jayco Terrain / Entegra Launch that came with a 48v 210ah system ( biggest lithium system ever )
I noticed that even with EVERYTHING turned off, its draining about 1 amp...
Only thing that is on is the inverter.
Is this normal? I have plenty of juice so running it down is not my main concern but still wondering what could be drawing this much amp.
Im a newbie with anything electric related btw lol
Would love some help!
WinEra70X is offline   Reply With Quote
Old 02-27-2022, 02:46 AM   #2
Originally Posted by WinEra70X View Post
Hi guys
Large inverters if they are just idling can take that much and more, plus depending on what you have for safety detectors and battery monitoring systems, they can easily add up to 1/2 amp also.
Old 02-27-2022, 02:52 AM   #3
Yeah 1A@48VDC (4A @12V) seems about right with the inverter on. My inverter alone draws 2.3A @12VDC at idle, and that is without the other parasitic draws.
Old 02-27-2022, 04:57 AM   #4
Hi guys
Congratulations.
That is a nice size battery pack. A customer and I recently put one the same voltage and capacity in a sprinter, along with an auxiliary 48 volt alternator.
It is a nice setup.
Harry
Some experience with auxiliary power
HarryN is offline   Reply With Quote
Old 03-04-2022, 09:55 PM   #5
Thank you for letting me know, it definitely helped a lot
Old 03-05-2022, 06:10 PM   #6
HarryN is the 48 volt Guru!
Old 03-05-2022, 07:32 PM   #7
If you count "research / suffering / more research / trying again because I am stubborn" - sure.
