Old 05-10-2018, 09:48 PM   #1
Default Outlets not working
I just purchased an used 2018 Roadtrek Simplicity. The outlets are not working even when hooked up to shore power. All the other appliances and lights are working.
Any ideas what be causing this?
Thanks
Candy
Fico4gapp is offline   Reply With Quote
Old 05-10-2018, 10:07 PM   #2
Thanks
Candy
Check the fuse
Check the GFI
Which appliances are working?
Fridge works on 12v DC
Lights work on 12v DC
microwave works on AC
THere could be a small inverter for the TV
Old 05-10-2018, 10:49 PM   #3
Thanks
Candy
The microwave works but the receptacles have no power?
Old 05-10-2018, 11:05 PM   #4
Microwave, TV, refrigerator, fan, lights are all working
Old 05-10-2018, 11:15 PM   #5
With shore power disconnected and the inverter turned on, same condition?
Old 05-10-2018, 11:22 PM   #6
It is probably covered on about page 31 of your manual, 2017 manual, mentioned above.
Old 05-10-2018, 11:49 PM   #7
It's not a blown fuse because the fuses in the panel address 12 volt circuits. But BBQ's suggestion to check GFIs seems spot on. The TV/DVD outlet is GFI protected and since the TV works, it's not tripped. But all the other 20V outlets are protected by a separate GFI which is in the breaker panel. Look for a tripped breaker.
Old 05-11-2018, 12:10 AM   #8
Thank you!! The reset button worked in the fuse box.
