Old 10-13-2019, 08:21 PM   #1
Default Onan 2800 Generator parts
Does anyone know the part number for the fuel pump and spark plug on a Onan Microlite Generator 2800 series? Also can you direct me where to buy these parts. Thank you all!!!
kalanute@live.com is offline   Reply With Quote
Old 10-13-2019, 09:17 PM   #2
What year and what is the exact model #. I've seen a lot of posts for 2800 microlite, but mine '2012 is a 2800QG (Quiet Gas) KVFA in case that makes a difference.
Old 10-14-2019, 10:21 AM   #3
Wandering Wes's Avatar
Search for and download a manual: "ONAN PARTS CATALOG 981-0238G"
Wandering Wes is offline   Reply With Quote
Old 10-20-2019, 06:24 PM   #4
Below is the fuel pump I just changed in my 2800 KV and it works great.
Airtex E11014 Electric Fuel Pump... https://www.amazon.ca/dp/B008KV4RNM?...p_mob_ap_share
soutram is offline   Reply With Quote
Old 10-23-2019, 05:57 AM   #5
Default Onan Genset
If you know the model number, I have brand new spark plugs, fuel pump, fuel line and muffler for Onan KV_KVC_KVD Microlite 2800 Genset off my 2004 RT Popular 190. I bought parts to refurbish/tune-up, instead, the generator went to the grave
Sunshine4220 is offline   Reply With Quote
Old 08-29-2021, 10:11 AM   #6
Old post but do you have the fuel pump and spark plug still?
Thanks
Archie Ice is offline   Reply With Quote
Old 08-29-2021, 03:00 PM   #7
Thanks
Unlikely since that was Sunshine4330's one and only post.
Old 08-29-2021, 04:59 PM   #8
Cummins Onan dealer. They are in most major city's.
Frumpster is offline   Reply With Quote
Old 08-30-2021, 06:32 AM   #9
Copy that.
Old 09-01-2021, 12:47 AM   #10
g1g
I bought a generic electric fuel pump at a local auto parts store and located in an easy to get to place. incase i had to do it again. So far no problems and its been about ten years now.
Old 09-01-2021, 08:00 AM   #11
8/31/21 - Onan 2800 Microlite FUEL PUMP
Apparently Airtex is no longer. Email I received from their websites contact page.
Hello,
The Airtex E11014 is an obsolete part today.
Since Airtex went bankrupt and was purchased by First Brands Group - they are now supplied by Carter Fuel Systems products, as they are also owned by First Brands Group.
The best option Carter supplied is the P74021, which does not have the 90 degree end - it is a straight through prump.
Thank you,
Technical Service - 800-342-6125
Hello,
It can be purchased under these numbers.
O'Reilly - E16368
NAPA - B-0203-E
CarQuest / Advance Auto - E2582909
Carter - P74021
You should be able to use one of those numbers to locate one local to you.
Thank you,
Technical Service – 800-342-6125
