Old 10-03-2016, 08:12 PM   #1
Default New H6054 sealed beam headlamps
Here's an animation showing the difference between the assumed OEM standard halogen sealed beam headlamps in my van and the Sylvania Xtravision replacements.
I think you have to click on the photo above to see the animation.
I wished I hadn't moved the shop light in between frames but, regardless of that, the new headlamps do appear to be slightly brighter, whiter and to project a much wider beam.
I did not look into switching over to LED.
While washing the van recently I noticed an impact crack on one headlamp. The outer surface was still smooth. The missing chunk is loose on the inside.
This was an interesting read: https://www.truthinadvertising.org/w...-complaint.pdf
I'll probably stick with standard or xtravision and not get any brighter headlamps.
