Old 07-31-2016, 07:35 PM   #1
Default Need to wire '06 Sprinter for small utility trailer?
My '06 T1N Sprinter does not have a trailer wiring package, so I need to start from scratch. I do not need to hook up trailer brakes, only lights. Can I simply splice into the existing taillight wiring? If not, where do I start the wiring. I'm looking for an inexpensive solution.
Thanks, Rick
lzcamper is offline   Reply With Quote
Old 07-31-2016, 07:44 PM   #2
Thanks, Rick
Yes you can splice into the existing taillight wiring.
Actually, you don't need to "splice" per se.
You can get the Y-cable (with sockets) specially made for trailer lights.
You simply plug-and-play.
Call your local trailer dealer/installer; they should have that Y-cable.
Old 07-31-2016, 08:19 PM   #3
Just to clarify my question with your response, " I need to connect my Sprinter's tail lights to the connector on the trailer and my Sprinter has no pre-wiring for a trailer. Are you saying there is a Y connector that will just plug into the tail lights of my Sprinter?
Rick
Old 07-31-2016, 08:28 PM   #4
Rick
That is correct.
If your trailer installer do not have it in stock,
they can splice one up for you on the sport.
Old 07-31-2016, 09:07 PM   #5
I can't help with any specific Sprinter info.
For my GM van I bought a Curt T-Connector. - http://www.classbforum.com/forums/f8...html#post35705 - It was specific to the make, model, year etc. for my van. The little converter box (part of the kit) has some current limiting functions.
The kit had plug/socket combos that you inserted inline on the van taillight wiring. There was no cutting or splicing etc. The end result was a 4-way flat connector at the rear of the van.
