Old 08-07-2017, 06:07 PM   #1
Send a message via AIM to sewright33 Send a message via MSN to sewright33 Send a message via Yahoo to sewright33
Default Main switch
I mean going to try my air conditioner on my leisure wide body van withe a generator
If it cuts out is there a main reset switch in my van
sewright33 is offline   Reply With Quote
Old 08-07-2017, 06:10 PM   #2
Default Reset
I am going to try a generator with my air conditioning and wonder if it cuts out is there a main reset switch in the van
1997 leisure wide body
Thanks Ann
Old 08-07-2017, 06:38 PM   #3
most gennys incl the common onan 2800 have a breaker on the genny itself.
remove the side panel and there may be a label, you reach down with your finger to reset it.
there may also be an automatic switch built into the rv part of your van to select shore or genny power
and then also circuit breakers for the ac unit on teh electric panel which hopefuly are labeled
mike
