Old 07-25-2018, 07:41 PM   #1
Default Made some upgrades
One thing I didn't like about my RT 210 Popular was the location of the shore power receptacle in the outside storage drawer. You have to bend down, try to see to align the plug and then you could not close the drawer. So, while in the process of installing a hard wired, Progressive EMS I decided to install an outside body mount shore power receptacle.
Previously I installed an LED porch light, I'm now reporting that it lights up the area, wall to wall and tree top tall. I liked it so much I added 2 of the smaller ones to the drivers side to illuminate the 2 slide out drawers and the area around if you hook up in the dark.
Old 07-25-2018, 11:18 PM   #2
Looks great. Please provide a source for the lights.
Old 07-26-2018, 04:28 AM   #3
Nice clean job!
Old 07-26-2018, 05:48 AM   #4
Both sizes are available from several sources, they are the lights that are aimed down 40 degrees:https://www.ebay.com/sch/sis.html?_n...72.m2749.l2658
This picture is the larger porch light.
Old 08-06-2018, 03:18 AM   #5
Default Parts used for 30 power and led lights
If you could share the brands and specs on times used it would be helpful to make the same up grades.
Thank you
Steven booth
2007 210 Versatile
Steven Booth is offline   Reply With Quote
Old 08-06-2018, 04:29 AM   #6
Thank you
Steven booth
2007 210 Versatile
Click his ebay link in post #4. Looks like his light comes in different sizes (lengths) and colors black, white, and silver. You may have to shop around ebay to find the right one for you.
Old 08-06-2018, 09:51 PM   #7
The shore power receptacle: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I chose the location for the receptacle because the RT shore power 10 gauge wire is routed to the original location in the drawer, directly behind were I cut the hole. Allowing access to the wire and to mount the receptacle. The hardest part was pulling the wire up from the OE junction box as the sealer around the wire at the top of the short piece of conduit was strong.
