Old 08-23-2024, 06:11 PM   #1
Default Lost all electrical power
I plugged my 2017 Road trek 210 into a friend’s outbuilding and the power went out.
I’ve checked fuses, tried resetting inverter, GFCI, eco trek modules, & battery disconnect switch, and running the under hood generator
I don’t have an electrical diagram. What else should I check?
Is there a fuse on the inverter?
I think there might be a transfer switch - or something - in front of the couch, but we can’t raise the power couch from bed position. Is there some way to do that manually?
I’d appreciate any advice
Fred O is offline   Reply With Quote
Old 08-23-2024, 09:20 PM   #2
is the outbuilding still providing power ?- if your air conditioning was on it may have tripped his breaker
does his socket have the correct power for your plug ? correct voltage, correct wiring ?
are you using a 30 amp plug ? or... ?
Old 08-23-2024, 10:25 PM   #3
Did you reset the building wall outlet?
Once it happened to me when I just plugged my RT 170.No AC or major power draining device running.
I just pushed the reset button on the wall outlet.
You most likely checked it 1st.Posting just in case.
RT1997 is offline   Reply With Quote
Old 08-24-2024, 12:11 AM   #4
We are no longer plugged in at friend’s house
We are at home; tried plugging in with our normal #12 cord from house
There is no power & no response from the charging system
Seems like a fuse is blown but I don’t know where to look after checking fuses in the panel & under the driver’s seat
Still wondering if there is a fuse for solar controller or inverter
Old 08-24-2024, 01:21 AM   #5
I cn trace how far AC is reaching your electrical system with a simple AC detector like this one https://www.google.com/search?q=ac+d...hrome&ie=UTF-8
or this one https://www.harborfreight.com/non-co...xoCHT8QAvD_BwE
Old 08-24-2024, 06:55 PM   #6
Thank you - I’m using one of those, and I have a multimeter, but can’t detect any power.
Solar controller won’t come on either
Old 08-25-2024, 10:07 PM   #7
Still looking for info on sitting the electric couch up without power.
Also, still haven’t found a fuse that is supposedly on the line from the lithium ion coach batteries to the inverter.
The battery box is sealed.
couch, electrical, general discussion, inverter, power outage
