Old 03-29-2007, 04:21 AM   #1
Default Looks like same motor as the Yamaha EF3000iSE
Boliy PRO3600SI Valves
Yamaha EF3000iSE Valves
Boliy PRO3600SI Piston
Yamaha EF3000iSE Piston
Boliy PRO3600SI Cylinder
Yamaha EF3000iSE Cylinder
Boliy PRO3600SI Crankcase
Yamaha EF3000iSE Crankcase
Old 03-29-2007, 04:42 AM   #2
The Yamaha EF2800i cylinder sure looks identical:
Yamaha EF2800i Cylinder
Both the Yamaha EF2800i and EF3000iSE use a 171cc motor. Most probably the same.
I'm not saying that the Boliy PRO3600SI has a Yamaha motor in it. I'm just pointing out that the motors look the same to me.
Old 04-01-2007, 06:05 AM   #3
Marco, you know the Chinese have become masters at copying other's designs to the minutest detail and selling that item at half the cost or less as any "western" company.
GM had a international lawsuit a couple years ago against a Chinese car company for copying a Korean model that GMDAT was making so closely that even the parts were interchangeable on the cars. GM lost the lawsuit because the Chinese government wouldn't abide by the international copyright laws.
Maybe this is the same case here with Yamaha???? Or maybe Yamaha owns part of this company and has designed your model or some, such idea????
Bob & Sharon
Old 04-01-2007, 03:37 PM   #4
My guess is that Boliy just purchases a ready made motor.
Yamaha may just purchase this motor also. There seems to be so many generators out there using a 5.5 hp, OHV, 171cc motor, Air Cooled, 4-Stroke motor.
Sort of makes sense that one or two factories produce it. I can't imagine a dozen factories tooling up to do it.
Old 04-01-2007, 04:21 PM   #5
You're right, about them just buying the motor from an outside source. Although Yamaha is a giant engine builder in it's own right. They've probably set up a factory in China to build this and other small engines. Especially since I notice you mentioned in another thread that the oil specs call for Yamalube.
Looks like a nice unit!!
Bob & Sharon
