Old 11-04-2021, 05:00 PM   #1
Default Is a fuse required?
Couldn't get an answer out of Renogy so I'm asking;
Do i need additional fuses, upstream and downstream on my Renogy MMPT 20A Rover controller or are they built in?
I'm just running one 100w panel and 2 x 105a/h lead acid batteries. #12 AWG for the controller to batteries and #10 AWG from panel to controller.
If so, what amperage should i go with?
thank you
ovsa is offline   Reply With Quote
Old 11-04-2021, 07:32 PM   #2
Default Fuses
Here are some pictures of info that should help:
Ken
Old 11-11-2021, 05:28 PM   #3
I agree with ks@yvr. Especially the "Wiring Diagram High Power"
ikanode is offline   Reply With Quote
Old 11-11-2021, 05:44 PM   #4
Fuses protect the wire. The device protects itself. So a fuse from solar panel to controller, fuse from controller to battery, based on the wire size.
