Re: inverter query...
a 2008 roadtrek only has a 750 watt inverter in the inverter/charger. you are correct-only the entertainment center parts-tv/dvd player work off the inverter. I think there is 1 plug in the kitchen section that also does-however 750 watts is not a lot of power for devices-using it will probably blow a fuse/pop breaker.
