Old 07-27-2020, 10:49 PM   #1
Default Inverter dead?
Hey gang, long time reader, first time poster.....
Roadtrek 2015 SS Agile
Onan propane generator
No second generator in front
Powerstar 300 (LW3000-12-C) Inverter/charger
Symptoms: No coach AC power with inverter on. I noticed my phone had stopped charging and my fridge stopped while driving. Error code on inverter said code 03 "Output short circuit". Shut off inverter to allow fridge to operate in 12v DC mode for the rest of the day. (If the fridge senses AC power, it uses that, otherwise it switches to DC and uses battery power). Batteries appear fully charged.
Stopped that evening, turned on inverter, turned on the Generator, and Air Conditioner would not run, same fault on inverter.
Turned engine on, inverter on, generator running, still no air conditioning.
Got home, and tested all on shore power, bypass working fine and can run air conditioner with generator on and inverter on. Pic 2
Breakers good, no fuses blown. What I can see with my limited skills, wires appear attached.
Thanks in advance,
John
Where do I start?
Rugert73 is offline   Reply With Quote
