Old 06-29-2018, 05:13 PM   #1
Default Inverter alarm
I have 2018 Roadtrek Simplicity. The inverter alarm is alarming. The rig was parked overnight with everything turned off and the battery disconnected. When I went in the inverter is alarming. Does anyone know why and what I need to do?
Thank you
Fico4gapp is offline   Reply With Quote
Old 06-29-2018, 09:45 PM   #2
If the inverter is alarming, that means the inverter is connected to the battery and is turned ON.
The inverter has an overhead draw. ie whether you have any appliances connected or not, the inverter draws a small amount of electricity from the battery. Over a long period of time, it can drain your battery.
Is the alarm related to low battery?
Old 06-30-2018, 02:06 PM   #3
Thank you. I did get it figured out by “cheating” with Roadtreck” support.
Thank you
Old 06-30-2018, 02:13 PM   #4
What did you figure out?
What do you mean by "cheating"?
