Old 10-16-2020, 11:26 PM   #1
kmessinger's Avatar
Default If you were going to add a soft start . . .
to your air conditioner what brand would you use? There are so many out there. Adding this to a my Travato.
2022 Winnebago Travato 59KL
2017.5 Winnebago Travato 59K
2008 Sportsmobile Sprinter
kmessinger is offline   Reply With Quote
Old 10-16-2020, 11:43 PM   #2
I installed Easy Start. Works as advertised.
Old 10-17-2020, 12:35 AM   #3
The Micro Air Easy Start. I installed on my Dometic 11K AC unit a couple of years ago. Watch the videos for your unit. Purchase the easy install kit. Saves time. Look for a discount coupon. I believe they are available for $25.00 discount?
Old 10-25-2020, 06:01 PM   #4
Hello, what is a soft start for the AC? I found a small portable AC and came up with an interesting way to vent in my 2020 Travato K. This also acts as a dehumidifier. Leaving in Florida I put the AC on when stored in my driveway and plugged in, on low fan and it does the trick.
Beachlife is offline   Reply With Quote
Old 10-25-2020, 06:46 PM   #5
The Easy Start allows the ac to start in phases. Like the fan first, than compressors, etc. This reduces the required start up amps on the generator/battery/electrical power sources. If you live in Florida. There is a person on FB Travato who changed his ac unit to the Houghton Belaire. It has a setting on it for humidity. Basically dries out all air. He swears by it and runs it daily. I just upgraded to this unit about a month ago. It has come down in prices since he purchased it 3 years ago. No need for Easy Start with this unit. It has variable compressor/ fan so starts in phases.
Old 10-26-2020, 03:30 PM   #6
Thank you so much. I don't like the loud AC, but really need something with a lower fan and drys the air as you said. I will check out the Houghton Belaire and see what it costs. Again take care and safe travels
