09-30-2023, 10:46 PM
House Battery Led Volt Meter
I have a 2005 Chevy Roadtrek 210. Is there an easy way to connect/install an Led voltmeter? I would like to install somewhere near the Monitor panel but can't seem to locate the hot and ground wires.
Thanks, Bob
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
09-30-2023, 11:06 PM
09-30-2023, 11:09 PM
I sure didn't explain myself very well. I want to monitor the house battery not the chassis battery. Thanks.
10-01-2023, 01:46 AM
Volt meter
Used a hole saw for a round LED volt meter in the panel with the other indicators. Also for a momentary push button to activate the VM. Attached the + to one of the fuse terminals and the - to ground.
10-01-2023, 01:53 AM
That's what I was going to do but I can't seem to locate the hot and ground. I am used to red being hot and black being ground. ????
10-01-2023, 02:03 AM
On the fuse panel, find a fuse that remains hot, connect the wire from the VM marked POS or +, attach it to the fuse holding clip. locate any point that is grounded and connect the NEG or - wire. I don't recall where I did.
Easier done than described.
10-01-2023, 03:27 PM
Thanks. Will be doing today.
10-02-2023, 03:05 AM
You have no 12 volt outlets running off of the house battery?
10-02-2023, 04:14 PM
To all, Thanks for your inputs. It made me think a little. I dislike cables and devices I have to leave plugged into receptacles. That's just me. Anyway, I loosened the fuse panel and found a hot and ground. Drilled a hole and fit a usb/push button volt meter in.
When you click on the picture it rotates to normal view.
10-05-2023, 05:19 PM
That's a very nice looking installation. Far superior to what I rigged up on our 210P. The important thing is you now have a convenient source to give you the voltage of your batteries.
Here is an easy to understand color chart that I printed out years ago and keep handing, although over the years I have pretty well memorized the voltage to percent charged depicted here.
https://www.rvtechlibrary.com/battery/bat_volts.php
10-06-2023, 12:07 AM
Thanks for the compliment. I enjoy working on things and try to do the best I can to make what I do nice. That's just me. Thanks for the chart.
