Great question. I don't know the answer either. Here's a quote from phred:
TEMPERATURE
Temperature is important when charging any kind of batteries. A really hot battery (EZ to achieve if they're sitting out in a cheap, plastic box) will overcharge well before the voltages listed earlier. Keeping batteries "indoors" helps keep them at about an ideal temperature (of about 68 to 77ºF). Actually, high temperature only becomes a real problem when the battery is being "floated." A 13.8 volt float can easily become a 14+ a-whole-bunch float at 90º. Temp can also be a winter problem as batteries try to freeze and their amp hour capacity is reduced by over 30%.
With "cheap" batteries I probably wouldn't do anything and just replace them more frequently. With Lifelines, it's worth figuring out the best way to do it.
Two 12v batteries would be easier manage separately, either with an A,B,Both switch, a high tech charger (two batt. banks, temp compensated) or a combination of both.
I wouldn't do anything special to compensate in my RV because of where and when I camp. (mostly Pacific Northwest in late Spring, Summer & early Fall). It's not really hot or cold.
