Old 08-22-2019, 07:06 PM   #1
Default Hook up new water line from water pump to faucet
How do you hook up a new water line tubing from water pump to the faucet in a 2005 210 P Chevy. What is the easiest tubing to use.
Whichwanda is offline   Reply With Quote
Old 08-23-2019, 01:13 AM   #2
Sometimes the faucets have connects you can purchase from the local hardware store. If you're comfortable making your own pex connections, it seems to be the tubing of choice for modern rvs.
Did you burst a pipe, loose a connection, or change faucets to a style that doesn't connect the way the original faucet did?
