Old 08-15-2020, 09:43 PM   #1
Default Help -Simplicity home battery location
I can’t seem to find the home battery on the 2018 simplicity? I removed the battery under the drivers mat and that was the starting battery. I,ve looked under both back seat cabinets and next to the inverter and it’s not there. Please help, I just bought it and wanted to replace it today.
Ender is offline   Reply With Quote
Old 08-15-2020, 09:47 PM   #2
Welcome, stand-by, someone smarter than I will be along
a check online shows a 2016 model, the batteries are located in a cabinet on the drivers side, to the vehicle rear of the inverter- the top flips up
Old 08-16-2020, 04:07 PM   #3
The house battery on all of the Roadtrek Promaster models is under the vehicle in a box towards the rear. Take a look under there and you can't miss it. Your problem will be dropping it for changing.
If you are a Facebook user, I suggest that you join the Roadtrek Zion and Simplicity group.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
