Old 09-17-2017, 04:08 PM   #1
Question Help removing Generac NP-30G from 98 Rialta RD
Where is the easiest place to disconnect the AC output wires so that I can take the generator out for service?
Jerry Schlei is offline   Reply With Quote
Old 09-20-2017, 04:04 AM   #2
There should be a junction box on the left side of the generator. You would see a corrugated metal conduit. Disconnect there and remove the ground wire. Best to remove the muffler and exhaust pipe before letting the unit down.
CGAZ Paul is offline   Reply With Quote
generac, np-30g, rialta, winnebago
