Old 03-04-2015, 05:11 AM   #1
Rok
Default Help: Generator Doesn't Provide 110v to GW Legend SE
We own a Great West Legend SE 2013 Model.
We were testing all the systems a few days before our first outing for the season.
Everything was testing fine until with the generator on all 110 V appliances stopped working. Turned the generator off then on again. Still no dice. It also wasn't charging the coach battery.
Hooked up shore power, all appliances worked, coach battery was being charged.
I suspect a breaker or fuse on the generator (I believe it's an Onan 2000 watt generator) or the power transfer module, but don't know where it would be found.
Has anyone else had this happen? How do you fix it?
Thanks in advance.
...........Rocky
Rok is offline   Reply With Quote
Old 03-04-2015, 12:35 PM   #2
Default Re: Help: Generator Doesn't Provide 110v to GW Legend SE
Most likely an Onan 2500 in your Sprinter RV Rocky. You're probably right about it being the breaker on the Onan as everything works on shore power.
Old 03-05-2015, 10:22 AM   #3
Rok
Thanks for the help Marco. Our unit is a bit different than your drawing. It was indeed the breaker. Had to crawl under the van, take a panel off, and fish my finger up & over and down around a protective cowling. Found the tripped breaker and reset it. Now everything is back to normal. Those Keurig Coffeemakers take some power, I guess. I had some other stuff on, too, to keep a load while testing the generator. My wife decided to test the Keurig at the same time, and I guess it was too much.
Yes, you're right it is an Onan 2500, not a 2000.
Anyway, everything is working O.K. now.
.................Rocky
