Old 03-29-2022, 03:38 AM   #1
Default Headlights periodically flash
On our last trip, both headlights would flash occasionally. It appeared it mostly happened when we hit a bump in the road. Also noticed my DEF gauge blanked out a time or two as well when the lights flashed but not every time. I believe my house battery is bad because it doesn’t hold a charge longer than about two days with everything shut off. We do not boondock so I’m not in a hurry to replace the house battery. Could the house battery being bad cause this problem since I’m sure it’s all wired together. We have a 2019 Coachman Gallery on a Mercedes chassis.
jbjtx is offline   Reply With Quote
Old 03-29-2022, 04:01 AM   #2
a duff battery will put a load on your electrical system
replace it or find a way to electrically isolate it so it doesn't load down your alternator ( such as removing teh negative cable(s) from the house battery
a $100 problem can become a $1000 problem if left as is.
issues with the van electrical system could be reacting to a load like from a bad battery- and relays dropping connection
given how delicate the computer controls are in an import, the high service costs and a possible supply chain across oceans.
take care of this
mike
Old 03-29-2022, 12:13 PM   #3
Thank u for that input. Thought of a few things but not that.
Old 03-30-2022, 08:51 PM   #4
Were it American the first course of action would be to replace the headlight switch which has a high current limit switch which can fail. It is a real trip to have the headlights fail at speed at night. It must be fixed.
Old 03-31-2022, 02:44 AM   #5
TomF's Avatar
If your vehicle has a light sensor in front of the rear view mirror, something blocking it will make the headlights flash.
1997 Roadtrek Popular
