Old 08-25-2015, 09:50 PM   #1
Default Group 27 6V AGM batteries!
After finding a group27 sized 6V agm I got a set.
They are 200AH 6v made by haze battery for Electric vehicle use.
I installed the 6V's in series in my Pleasure way traverse van . A perfect fit, finally a decent battery capacity to run off. I had a sz 24 agm before (came with the van)..
http://buyabattery.com/pdf/HZB%20EV6...%20301111S.pdf
GtDad is offline   Reply With Quote
Old 08-26-2015, 01:27 AM   #2
Does this equal 400 amp hour 12volt? or 200ah 12volt?
eurovanman is offline   Reply With Quote
Old 08-26-2015, 03:08 AM   #3
200ah at 12v so just a little less than a single 4D sized 12v battery
Old 08-26-2015, 05:25 PM   #4
I think that is a smart move on their part, especially for the folks that have the two batteries aren't close together.
How does the price of them compare to the other AGMs, like the Lifeline 12 volt group 27, which would be the same amp hours?
Old 08-26-2015, 06:58 PM   #5
The haze group 27 Agm 6v's are are 250 Canadian each.
From what Ive seen a single lifeline 27 is about 350 is usd each.
So the haze are a pretty good deal in canada .
Two 6v inseries is a easier to charge setup and has less potential for damage than two 27's in parallel . In parallel if one battery goes down the other may be overcharged =dangerous and expensive
