Old 03-23-2020, 08:35 PM   #1
Default Generator won’t stay on
I just purchased a 2018 Mercedes/Winnebago Era 170A. It has an Onan generator QG 2500 LP with 10 hrs on it. When starting, the generator runs for 10/20 seconds then cuts out. Same when I run the LP burners in the galley. Vehicle may have sat on the dealers lot for a while - and my 30 day warranty has run out. I read the regulator may need to be replaced. Any suggestions? Any suggestions on where to take it in the Charleston SC area? Thank you!
Steve Lesniak is offline   Reply With Quote
Old 03-23-2020, 09:42 PM   #2
Hi: It sounds like your propane regulator is not working properly. You can have it tested or you can just replace it. If you have easy access to it. I would just replace it with a new one. Even brand new vehicle's propane regulators go bad very quickly.
