Old 10-27-2020, 12:55 AM   #1
Default Generator won’t start?
Hi everyone!
We’re brand new to the class B experience, so sorry if I ask a dumb question! We just bought a 2013 Pleasure Way Sprinter that has a Cummins Onan generator. When we were buying it two days ago it had a difficult time starting, but it did start. Yesterday I tried several times to start, and it turned over, but wouldn’t catch. Today it won’t so much as turn over. In fact, the light in the start switch doesn’t illuminate. I’ve checked and cleaned the electrical connections, which didn’t help. Anything I’m missing before I take it in to the shop? Thanks so much for any reply!
Peter
Petyosk is offline   Reply With Quote
Old 10-27-2020, 01:24 AM   #2
Is your "house"* battery fully charged?
and the switch for the battery is "on"?
* house is the battery for the coach as opposed to the vehicle battery under the hood ( or under the floor on some models)
also with a starter- any starter- do not run for more than 20 seconds- then allows a few minutes cooling time before trying again
Old 10-27-2020, 01:32 AM   #3
Yeah, sure sounds like a weak house battery.
Try starting it while the chassis engine is running, or while plugged into shore power.
Old 10-27-2020, 03:03 AM   #4
The house batteries seem fully charged, and they’re switched on. I’ve also tried to start the generator both while the engine is running and also hooked up to shore power. It does seem as though it’s an electrical supply problem, but the batteries are showing charged.
Old 10-28-2020, 01:02 AM   #5
eric1514's Avatar
How much gas to you have?
"Il Travato Rosso"
2015 Travato 59g
Old 10-28-2020, 06:19 PM   #6
If your battery is fully charged, it fires,but don’t hold, has a quarter tank of fuel, I would throw in a can of SeaFoam Gas Additive. You say it is a ‘13, so you real,y aren’t sure of how well it run before. Ron
Ron J. Moore
'15 RT210P
Old 10-28-2020, 06:38 PM   #7
Thanks for all the advice! I hadn’t mentioned it was a propane generator. I took it in finally, and it turns out it was two problems (I know, not fair, right?) Originally the generator was shutting down because the intake hose was leaking, and then the CB was eventually tripped. I did check the breaker on the unit itself, but I guess there’s another? Anyway, thanks for all the advice, I appreciate it!
