Old 05-06-2021, 08:13 PM   #1
Default Ecotrek operation question
hello everyone, i got a Roadtrek Ecotrek question.
if you turn the ecotrek switch on & you hear the relays engage & the unit turns on/powers up and is working properly, what happens if you push the reset? do the relays cycle? does it shut down while you are pushing the switch?
i've read thru most of the threads on the ecotrek system but not seen anything about my question. thanks
roady is offline   Reply With Quote
Old 05-07-2021, 01:44 AM   #2
PaulB-2006 T4R's Avatar
When I turn on my EcoTreks I need to power on then press and hold the reset. I release reset once I hear them engage or click. If your batteries turn on with just the on switch then they are on. The reset button will reset the batteries if they are on but unnecessary.
2018 Carado Banff with EcoTrek
PaulB-2006 T4R is offline   Reply With Quote
Old 05-10-2021, 08:00 PM   #3
thanks. i wasn't the first one inside the module. it took a little rewiring but think i got it going right. i hit can reset and the relay turns on & stays on as long as i hold it, i can turn it on with the switch & the relay clicks on & powers up the DC side & inverter.
