Old 05-31-2020, 09:50 PM   #1
Default Drained Li-on batteries
I let my Li-on batteries drain on my PW Lexor TS. Now what?
Tom 98072 is offline   Reply With Quote
Old 05-31-2020, 10:11 PM   #2
Hi Tom,
welcome to the forums ( which are running a little draggy today)
someone smarter than me will have some help- assume you tried the search function
cheers, Mike
Old 05-31-2020, 10:55 PM   #3
Have you tried charging them (plugging in or driving)? Lithium batteries typically have a BMS (battery management system) that automatically disconnects the battery to prevent damage to it due to overdischarge. Applying a charge voltage to the battery should re-activate it.
Old 06-01-2020, 01:09 AM   #4
Welcome Tom.
Some Lithium batteries shut down at low voltage and need a certain type of charger to "wake" them back up. Do you think this is what has happened to your battery?
What brand battery do you have? Can you contact them tomorrow?
Good luck.
Old 06-01-2020, 12:56 PM   #5
What year Lexor? I have 2016 and have run my batteries down. They just recharged back up?
Old 06-08-2020, 02:12 AM   #6
TheMatrix's Avatar
If your PW has a GU, maybe just driving around with your Li-Ion batteries turned on will charge them or wake them up? Worth a try if you haven't done so already.
TheMatrix is offline   Reply With Quote
Old 06-08-2020, 03:47 PM   #7
Some better quality BMS devices have a reset button.
Sehc is offline   Reply With Quote
