Old 06-07-2018, 06:53 AM   #1
Default Dometic propane cooktop w/ elec igniter
I have a 2017 Winnebago Travato 59k with a propane 2 burner Dometic cooktop. The igniters have quit working. Both at the same time. Lighting burner with match works fine. Have not been able to ID fuse location. Anyone have an idea?
Steamjockey is offline   Reply With Quote
Old 06-07-2018, 12:08 PM   #2
We too have a 2017 Travato K but don't use the propane burners. Our T is not here for me to check. You may want to check with the very knowledgable members on the Facebook Travato site.
Gail
2017 Travato K
Gail Staton is offline   Reply With Quote
Old 06-07-2018, 01:12 PM   #3
could be a loose wire... you have to lift the top to see.
Old 06-07-2018, 01:31 PM   #4
eric1514's Avatar
+1 Probably the ground wire. On mine, you can see if that's the problem by opening the cabinet door below it.
"Il Travato Rosso"
2015 Travato 59g
