I can only get AC power by turning on the inverter, even when plugged into shore power. I was told fridge wasn't connected to inverter, but mine apparently is - indicator lights up.
By the way, what's the difference between power saver vs nonpower saver mode on inverter? Manual just recommends "non" for general use.
Also, my burners could be lit with build in piezo unit that has failed. Can that be replaced?
Thanks for all the feedback.
