Old 05-01-2021, 07:35 PM   #1
Default Doa - propane gas alarm??
Ordered a new propane gas alarm, model 30-442-P-WT, for our 2000 RoadTrek V-200.
Checked the wiring and confirmed the hot wire; I have 11.89 volts coming through.
Temporarily connected the gas alarm to check that it was functioning properly. Came back ten minutes later and nothing; no red or green LED light showing.
Shaking my head. Will contact MTI on Monday for help.
Any thoughts appreciated.
HorseshoeCat
Horseshoecat is offline   Reply With Quote
Old 05-01-2021, 10:30 PM   #2
these are meant to be replaced periodically
a previous owner of my van had messed up the wiring- which I discovered when tracing back another wiring problem
"his" ( or her) wiring had an intermittent connection with a wire nut
on my pleasure way the wiring behind could be inspected under the sofa by lifting the cushions
have a look
Old 05-01-2021, 10:53 PM   #3
What is the minimum rated voltage on the unit. When you get below 12 volts sometimes it can be dicey to keep running. That is a pretty low battery if nothing else was running.
Old 05-02-2021, 10:58 PM   #4
True. But once I drained my battery during the night (heater) and when the alarm reached critical voltage it did start beeping. Was that the LP alarm or the CO alarm, I'm not sure. I also don't know how long it will beep before giving up. I cured it by running the engine for about 5 minutes. Later replaced the cheap house battery with a LifeLine.
Old 05-02-2021, 11:44 PM   #5
I recently had a 200 amp hour gel battery installed and I will have to check it out. The battery monitor shows everything is okay. I will have to do more checking.
Thanks.
HorseshoeCat
Old 05-02-2021, 11:46 PM   #6
Will be going on a road trip Monday so I plan on checking it again. However, as best I can tell, my new battery is okay.
Appreciate the insight.
HorseshoeCat
Old 05-02-2021, 11:48 PM   #7
have a look
The rear passenger seat comes off and the wiring is accessible for about 2 feet before it disappears into the wall.
I plan to do some more checking on this problem when I return from this next road trip.
I fully agree that the propane gas detectors should be replaced.....according to the manufacturer, it is every 5 years. I think I have seen some that say 10 years.
Just trying to be safe. Thanks for your insight.
HorseshoeCat
Old 05-03-2021, 01:35 AM   #8
on my van the CO detector is my "low battery warning"
found out the hard way- well not hard, just inconvenient
mike
Old 05-03-2021, 02:39 AM   #9
I don't know why your monitor would say under 12v is "OK" whatever it did say. That is a very low battery.
