05-10-2019, 05:34 PM
Coach battery box slide arms
The slide arms on the coach battery box on our 2007 Roadtrek 210 Versatile have lost thier ball bearings making opening and closing a little difficult.
Dors anyone know of a source to purchase these?
Thanks
05-11-2019, 07:54 PM
They are available on the internet or from a speciality woodworkers store. Ideally you would get stainless steel sliders but I was unable to locate any in the form factor/weight rating required. You need 200# weight rated sliders, 0.50inch thickness and 12.0 inches in length. These are originally secured to the drawer with pop rivets and you should get an air tool to accomplish this (Harbor Freight $40). You will need to remove the entire box: this is secured to the struts below with flat topped Allan bolts 1/4X20 unit aircraft nylock nuts below and 4 or 6 self tapping sheet metal screws (primarily for alignment purposes). You should take the drawer front off before proceeding with the removal. Drill out the pop rivets. These can be replaces with #14 sheet metal screws at reassembly. The slides cost me about $85 from Cabinetmakers Supply (a national chain).
05-11-2019, 11:19 PM
Does anyone know of a source to purchase these?
Thanks
Sorry for your problem, but a good reminder to the rest of us to keep those slides & bearings oiled up. Between battery fumes, water, and road dirt, those things take a beating.
Good advice for those who need to do the same replacement/repair to their battery compartment. Thanks.
05-16-2019, 05:41 PM
Thanks for the detailed info, but please be more specific on the exact slide arms (part number?) you ordered from Cabinetmakers Supply. Much appreciated!
05-16-2019, 06:05 PM
Yes please, part #s would be a great help!
Thanks
05-16-2019, 06:27 PM
Unfortunately I no longer have the receipt. The important issues are:
---12 inch overall length
---0.50 inch slide thickness side to side (otherwise it won't fit)
---double extension preferably releasable(to allow the drawer to be removed)
---200 pound rating (this one is important!)
---Stainless steel IF YOU CAN FIND THEM, I couldn't
---SS POP rivets if possible. If you have to use screws use as many as you have holes for!
05-17-2019, 08:57 PM
I have been searching the Cabinetmakers Supply website and there are a bunch of sliders on there. It is very confusing trying to find the correct one to order. When you say 0.50 inch side to side, it that the thickness/width or is it the height of the slide? The only one that seems close is this one: Accuride A3640 - Accuride Ball Bearing, Full extension Drawer Slides
05-17-2019, 10:57 PM
Finding slides, especially in stainless steel can be a challenge. I found it easiest to go to the Thomas Register site and find who the manufacturers are and then go to their sites to see all the available slides and ratings. Once you know what you want, it is then easy to Google search the part numbers to find out who sells that particular part number.
05-18-2019, 01:04 AM
Thickness refers to the side to side dimension.
