Old 12-07-2020, 02:29 PM   #1
Default Buck-Boost 26v at input terminal
I set up a new 50A Victron Buck-Boost in my MB Sprinter RV to charge 12v LFP batteries from the alternator. If I test the line-in cable at the alternator/starter battery end, it reads 13.1v. When I test it at the Buck-Boost input terminal, it reads 26v. Can someone help me understand why this is happening and what's wrong with my installation?
MarCorpsMustang is offline   Reply With Quote
Old 12-07-2020, 03:41 PM   #2
Originally Posted by MarCorpsMustang View Post
...... When I test it at the Buck-Boost input terminal,..........
Is that the output terminal?
If so, seems like it is set for 12V to 24V conversion. It's programmable via Windows PC so take a look at the settings.
Old 12-07-2020, 04:13 PM   #3
No. It's the other end of the cable running from the starter battery/alternator. 13v at the alternator end; 26v at the buck-boost end when connected to the buck-boost input terminal. How is that even possible?
Old 12-07-2020, 05:43 PM   #4
Where are you getting your ground reference?
Old 12-07-2020, 06:04 PM   #5
Off the BMV-712 shunt
Old 12-07-2020, 06:09 PM   #6
Sorry; that wasn't much of answer. Yes, tapping into the BMV-712 shunt, which in turn is grounded at the Xantrex Freedom SW 3000W inverter/charger that charges the same set of LFP batteries I want the buck-boost to charge..
Old 12-07-2020, 06:18 PM   #7
What does that voltage read when it is not connected to the buck boost but just open. If it reads OK, you must have a bad unit or ground on it. The odd part is it should back bleed out of the input unless it just goes to the alternator where the diodes would hold it up.
Old 12-07-2020, 07:11 PM   #8
When not connected to the buck-boost the voltage reads zero.
Old 12-07-2020, 07:56 PM   #9
If it reads 13+v at the other end of the cable and zero at the buck boost end when disconnected, it would be very odd and a bad cable or breaker, I think.
Old 12-08-2020, 04:16 AM   #10
Thanks, Booster. I was afraid of that. I sincerely do not wish to run another cable, but that may be what I'm faced with.
Old 12-08-2020, 12:51 PM   #11
Before you consider running a new cable be sure to look for breakers and fuses in the line. Most OEM setups will have a breaker on each end of the cable because of the two direction current they carry.
Old 12-08-2020, 01:23 PM   #12
I sure will; thanks. I put fuses on both ends of the cable I ran and will check them again.
Old 12-09-2020, 08:38 PM   #13
Issue resolved! It was a bad ground, something wise forum members tried to tell me, but this gnarly old Gyrene wouldn't listen. Thanks for your patience and assistance!
Old 12-10-2020, 04:03 PM   #14
Thanks for posting the solution.
