Old 12-23-2021, 07:11 PM   #21
Yes, that will take care of the wiring. You still have to do the programming.
Old 04-23-2022, 09:13 PM   #22
CanuckRV's Avatar
Well, it has finally warmed up enough to get out to the roadtrek to get the DVB01 wired in and programmed.
Everything was going fine until I got to step 19 of Mike's programming example when setting the voltage to 13.6 as per my voltmeter when I got above 9.9 I did not get a ten I got F0.0 is the F suppose to be a one or have I screwed something up. Right now I have it set as F3.6.
Thanks for the help
On Canada's South Shore
https://galavan.blogspot.com/
CanuckRV is offline   Reply With Quote
