I wonder if this one will be available in the US soon?
New Product Pro2600Si
DIMENSIONS & PACKAGE & OTHERS
DRY WEIGHT:28Kg
FUEL TANK CAPACITY :8.3L
NOISE LEVEL :58dBA
GENERATOR
TYPE: AC OUTPUT, Multistage permanent-magnet generator
RATED OUTPUT :2300W
MAX OUTPUT:2600W
RATED VOLTAGE: 120/230V
RATED FREQUENCY :60/50Hz
RATED CURRENT : 25/13A
DC OUTPUT : 12V 8A
Engine
TYPE: 166F, OHV, AIR-COOLED, 4 – STROKE
STARTING SYSTEM: RECOIL START
CYLINDER ARRANGEMENT: INCLINED,SINGLE CYLINDER
IGNITION SYSTEM: CDI
SPARK PLUG TYPE: BPR4ES( NGK ) / F7RTC
GAP: 0.7-0.8mm
DISPLACEMENT:171cc
ENGINE OIL QUANTITY :0.6 L
Product Certifications: CE & E/MARK(STAGE TWO) & EPA
Product Performance: enough juice to power up most 15,000BTU RV air conditioners.
