Old 12-19-2008, 12:01 PM   #1
Default BOLIY 2009 Pro3600Si have a great improvments!
From now one BOLIY Pro3600Si have many improvements, please checked the following:
1.Use include engine support pad Assy.
2.Use new wire connector.
3.Use new DC rectifier.
4.Use new step controller.
5.Use new heat insulation fuel tank.
6.Use new cooling back case.
7.Use new right case.
8. Use new material fuel pipe.
9. Use new fuel pipe clips.
10. Use new fuel level gauge.
11. Use new tools bag.
12. Use new drain oil method.
13. Use CSA approval serial bar decal.
14. Remove front and back small door rubber gasket.
boliy2009 is offline   Reply With Quote
Old 12-19-2008, 12:07 PM   #2
Default Re: BOLIY 2009 Pro3600Si have a great improvments!
The following is contine...
Old 12-19-2008, 12:16 PM   #3
New 2009 BOLIY decal!
Old 12-19-2008, 12:26 PM   #4
Default BOLIY Generator COLOR
I just get on BOLIY pretter color pic.
Old 01-21-2009, 05:43 AM   #5
Default BOLIY Pro3600Si will use electric start!
BOLIY electric start type will be put onto market in March 2009!
Old 01-21-2009, 05:45 AM   #6
Default BOLIY will make out 6KW water cooling generator.
BOLIY will make out 6KW water cooling generator. It will super silence, and more powerful! It is so easy power up 2 RV roof air condition!
Old 01-21-2009, 05:46 AM   #7
Default BOLIY 2kW wind generator will be sale!
BOLIY 2kW wind generator will be sale in April!
Old 01-27-2009, 02:31 AM   #8
Default Re: BOLIY 2kW wind generator will be sale!
That's interesting.
Post the specifications and some photos if you can.
Old 02-07-2009, 06:02 PM   #9
www.boliypower.com get more information
