Old 04-13-2023, 11:54 PM   #1
Default BMS charge question
I may be buying a new BMS. I now have a 150A BMS that may be bad, 280A battery and 280A 2nd alternator. Im currently using a Renology 60A DC2DC converter to charge the battery, all has been in about 2 years.
I was thinking of moving up to a 300A BMS and dumping the Renology but I see all that I have found that the charge current is limited to 150A.
Does that mean the BMS will shut down if the charge current rises above 150A?
larrylwill is offline   Reply With Quote
Old 04-14-2023, 02:21 PM   #2
@Michael's Avatar
I suspect that the answer to this would be dependent on the make, model and version of the particular BMS.
2019 Coachmen Crossfit
