Old 04-29-2022, 03:13 PM   #1
Default Blinker Woes RT200/Chev 3500
On my 2001 RT 200 Popular on a Chevy 3500, the blinkers work normally until I step on the brake or turn on the headlights, in which case the blinkers go into super fast mode. Blinker relay seems to be a mystery on the 3500. I haven't checked all bulbs but it does blink normally until I brake or turn on lights.
Any ideas?
Thanks!
Snoshoovt is offline   Reply With Quote
Old 04-29-2022, 03:35 PM   #2
Any ideas?
Thanks!
That kind of issue is commonly a ground issue causing feedback between the circuits.
There is probably a common ground point somewhere under the dash or behind the one of the footwell side kick panels, quiet often the driver side one.
Clean up the ground connection with fine sandpaper and make sure it is tight.
Old 05-01-2022, 12:06 AM   #3
Thanks Booster, I'll check the connections, here's hoping...
John
Old 05-01-2022, 06:35 PM   #4
Growing up when bulbs lasted months, not years or decades
I frequently check all the signals and lights are working correctly
on many vehicles a rapid flash is a reaction to an incorrect load on the flasher used as a warning indicator to the driver
do a walk around, get someone to work the turn signals and brakes to check lights- check any auxiliary wiring including a trailer plug for problems, frayed wires grounding out etc
a dull or dim light usually indicates a bad ground ( like when you see oncoming traffic and 1 headlight is dim) an easy fix, usually loosening and brightening the ground connection
mike
Old 05-04-2022, 12:42 AM   #5
Thanks Mike, working on it...
John
Old 05-04-2022, 02:22 AM   #6
also- check each individual bulb
if you have dual filament bulbs where the filaments are touching( due to a fault) you can have funny problems
stay away from walmart/amazon/ebay LEDS- the quality on many of those is poor
the best name in lights is Philips in my opinion
mike
Old 05-08-2022, 05:54 PM   #7
Our '01 200 on a 2000 Chevy 3500 chassis recently had a similar problem. I replaced a burned out backup bulb. All of the lights went nuts. There was crazy crossover between the turn lamps, brake lights, headlights, backup lights. Also the cruise control would disconnect when I signaled. I replaced the new bulb with another (same manufacturer & #). All went back to normal.
Old 05-08-2022, 06:37 PM   #8
also check the flasher relay- if you are not the original owner it may have been replaced with something less optimal
your vehicle is new enough to have come with an electronic flasher rather than thermal type
a thermal type depends on a predetermined resistance to make then, break connection
an electronic will work within a wider range
mike
Old 05-08-2022, 07:29 PM   #9
It's one of your bulbs 99% of the time...all these complicated long drawn out answers
Old 05-10-2022, 12:05 PM   #10
Default Flasher relay
Flasher relay was the problem, though in the process I found out GM can’t get them, the parts stores give the wrong one, and the taillights lenses have no screws, only adhesive caulk and sticky tape. Finally got the right relay at NAPA by cross referencing the part number which fortunately was still visible.
Thanks all
John
