Originally Posted by TooMuchHair
The MB specification of 8500 watts is "Input watts". The Volta Power 8000 watt alternator specs show the efficiency of that unit to be "80% typical". So that would be require 10,000 watts of input.
https://voltapowersystems.com/wp-con...ts_3.16.18.pdf
I'm not trying to split hairs, but they are exceeding MB's limits.
Plus there already have been many reports of belt issues using alternators with much lower output than the one we are talking about. Many of those include an engine overheat due to the loss of the water pump drive, that to me is an even bigger concern.
Love the forum and appreciate all of your well informed posts!
Good info - thanks. Those Volta alternators are certainly higher output than the commonly used Nations unit at about 4000 watts.
Guess it would depend on which level of B-van kit Winnebago and ARV are using since the level 2 kit has a 6000 watt alternator. The level-3 kit uses the 8000 watt alternator.
https://voltapowersystems.com/wp-con...1.8.17_WEB.pdf
Volta does say both level 2 and 3 kits are compatible with the Sprinter, Promaster and Transit vans. Did notice that specs for the 6000 watt alternator lists "Ford, MB and other small diesels". The 8000 watt unit lists "GM, Ford and others". The actual load can be adjusted by pulley diameter. Both alternators list custom external regulators on the spec sheet. Without specific details of each installation can't be sure if limits are exceeded. I'd imagine Winnebago and ARV have made adjustments to keep the load withing the MB limits.
Here is a setup from the audio junkies with real belt problems.
