Old 06-08-2024, 07:18 PM   #1
Default Auxilary fuse block in front of battery on a 2006 RoadTrek Adv
I was going nuts trying to figure out why my new(ish) to me 2006 RT kept losing voltage to the Victron I put in to charge the LiFePo batteries. Took an hour of crawling down around and under to find out one of the two previous owners blew the fuse that goes from the starting battery to the isolator. Then instead of replacing it, they wired in a circuit breaker of indeterminate amperage via jumpers and electrical tape.
Best guess is that it is 20 amps because when the Victron wanted the full 30 it can use, the breaker kept tripping. Off for a second then resetting.
I understand why a shade tree would do that because finding the right replacement fuse was a biatchico. The closest replacement I could find is a littlefuse ‎0498070.TXN‎ from Digikey. I could find a bunch of 70 amp midi fuses cheap but they are about twice the width and a little long to fit in the holder. It will be a few days until it comes and I'll post pictures.
I guess when they were changing out the coach battery they must have shorted it out. No other way it would have blown.
Richard Cranium is offline   Reply With Quote
Old 06-10-2024, 12:27 AM   #2
Pics of the "solution" from whoever previous and closed up.
Old 06-13-2024, 10:12 PM   #3
Done. 10 minutes total with extra no -corrode time.
Fuse came from DigiKey in 4 days.
You have to remove all the nuts from the top bar to get any fuse off.
It's not pretty and clear like the others but it isn't a half baked jumper either.
I highly recommend the conductive no corrode whenever you do electrical. A little corrosion will wreak havock on radio reception and this stops it.
Old 06-14-2024, 10:50 AM   #4
Interesting... Thanks for sharing.
pasusan is offline   Reply With Quote
