Old 07-26-2020, 04:12 AM   #41
Hi: Here is a link to the new Onan inverter generator by Fit RV. You can skip to about 8 minutes.
What do you all think?
Old 08-04-2021, 01:16 AM   #42
Default Question
Probably not as great a market as there was, but there are lots of folks that are fed up with Onan in general, and lots of applications, so I think still plenty of market. Would this be short enough to do the underbody mounts? New Onan at 65db, quieter than that, I would hope?
Do you know if this is a direct replacement to the older MicroLite 2800? Thanks David
BamaDave is offline   Reply With Quote
Old 08-04-2021, 01:34 AM   #43
Close. We still don’t have a report from someone that did his own upgrade and could relate to us the complications.
Exhaust changes seem to be the major complication. The old exhaust pipe probably won’t work complicating the upgrade.
Old 08-04-2021, 02:24 AM   #44
If it helps, we did the following (recently completed, and tested on 3 camping trips so far:
1: replaced our 2 AGM batteries with Li-Ion
2: installed a high end charger/inverter
3: installed a 2nd high-output alternator in the engine.
Now, if we want a generator, we just run the quiet, efficient, works-at-all-altitudes engine.
next step is to pull the generator out completely and install a bunch of batteries in it's place.
-RV's, Firearms, and Bourbon
-Weekend warrior
BigFatGuy is offline   Reply With Quote
Old 08-04-2021, 11:48 PM   #45
I believe you'll be very satisfied when you drop the generator and install more batteries.
During late winter/early spring of this year I made these changes to our 2020 Galleria.
a. removed the factory-installed generator.
b. removed the factory-installed 330ah AGM battery.
c. installed twelve 105 ah lithium batteries.
d. installed a Nations 3-belt 280 amp aux. alternator.
We're pleased with these new changes.
2020 Coachmen Galleria 24A
dmb496 is offline   Reply With Quote
