Old 06-05-2020, 04:27 PM   #1
Default Anti theft module
I have a friend here in Canada who has a 2002 road trek poplar that won’t start. She had it at the dodge dealer for 3 months before they came up with the the theft module was no good and they could not find a replacement. Is there a way of bypassing this module to start the engine. Or anybody have a good idea to get her on the road.
dutchduo1990 is offline   Reply With Quote
Old 06-05-2020, 05:01 PM   #2
if that is a "roadtrek" module hopefully someone will know how to bypass it- it is marked in any way, maker, model # etc.
If a dodge part, check more dodge specific forums.
mike
Old 06-05-2020, 05:14 PM   #3
She gave me two model numbers.
56021861AL. And
56021861AK
Old 06-05-2020, 05:34 PM   #4
That IS a dodge part number
internet shows no longer available from chrysler, but there may be an updated model available- you need a dodge specialist
and a high failure item, which is used for many functions beyond anti-theft
http://starparts.chrysler.com/tsb/en...dc80c84c7a.pdf
good tip to pull fuse #13 and then test again
( note that 315 MhZ radio frequency can cause this to fail...like added CB radio*)
If the Dodge dealer can't sort it out she is either screwed completely or at the wrong dodge dealer
dealers tend to hire new techs right out of school, short on experience and with book learning of model from recent years only
I'd start calling around
I do not know IF that diagnosis is truly the problem and if the module is a straight swap or it it needs to be programmed
*the mobil speed pass gas pump often interferes with Harley modules and the bike has to be pushed away to start it up
Old 06-05-2020, 06:22 PM   #5
reading up this failure is common and the "dodge" forums are full of complaints, tests and remedies
the module controls more than just the anti-theft
08-26-00-2-SYMPTOM/CONDITION:Strong electromagnetic fields or devices that transmit signals in the 315 Mhz range maycause the Central Timer Module (CTM) to intermittently lock up. CTM lock-up may causea variety of customer complaints including:Remote Keyless Entry MalfunctionInterior Lights Will Not Come OnIntermittent Wipers Will Not FunctionChime MalfunctionPower Door Lock MalfunctionRemote Radio Switch Malfunction (if equipped)Heated Seat Malfunction (if equipped)Engine Will Not Start (if equipped with Vehicle Theft Alarm)No Communication With The DRBIII (No Response from CTM)Essentially, all CTM controlled devices will not function if the CTM locks-up.Customers that do experience this condition may:-have their vehicle equipped with after-market accessories that emit strongelectromagnetic signals such as high output Citizen Band (CB) radios or Two-Wayradios.-be equipped with transmitting devices that operate in the 315 Mhz range such asolder analog garage door openers.-live or drive near devices that emit strong electromagnetic signals such as two-wayradio communication towers utilized by the military, law enforcement, etc.
the van owner can find out for themselves by searching
