Old 01-03-2017, 07:07 PM   #1
Default Adding 2nd solar charger
so my foldable solar panel with the battery tender solar charger is doing a fine job of keeping my engine battery charged and now I am wondering if it would be okay to splice in another feed to another solar charger to keep my coach batteries charged at the same time - what do you think?
Old 01-03-2017, 07:33 PM   #2
What is your panel's wattage?
How many house batteries do you have?
What are the total AH?
Old 01-03-2017, 09:21 PM   #3
The panel is 70 watts, 2 100ah batteries
Old 01-05-2017, 12:51 PM   #4
Well, I reckon I'll have to wait until I purchase another panel before I hook up another solar charge controller for the coach batteries.
Old 01-22-2017, 05:52 PM   #5
Probably require second charger/controller if panels have different voltage. Roadtreks have little real estate for panels so our son designed system with a 100 W and a 315 W panel. These are approximately 12 V and 30 V respectively and he used two controllers. The battery suite is 360 A-hr LFP at 12 V nominal (14 V actual). The battery suite in our fifth wheel is 48 V nominal since power comes from panels at 90 V.
Reed is offline   Reply With Quote
Old 01-23-2017, 12:27 AM   #6
Originally Posted by Reed View Post
Roadtreks have little real estate for panels......
Really? For little real estate, RT seems to provide quite a bit of solar compared to
the class B WGOs whose solar option is only 100 watts.
Agile & Zion, up to 300 watts
Sprinters, up to 470 watts
XL Sprinters, up to 600 watts (with warp core option)
Old 01-23-2017, 01:25 AM   #7
RT has little space compared to our 5th wheel which has 1400 W and we could install two more 235 W panels if we so desired. RT has lower power requirements so economy of scale
solar charger
