Old 07-10-2021, 04:53 PM   #1
Default Ac power not working
Just bought 1990 Ford econoline Falcon.
Can’t get AC power working.
There never was a generator.
The 12volts work , but I can’t get AC to work.
All breakers are on, after I plug it into the house.
Outlet is on where I plugged it in.
thanks
File Type: jpeg 6F983F5B-4B8A-4E49-817B-4852E50F4EF7.jpeg (99.0 KB, 4 views)
Falcon90 is offline   Reply With Quote
Old 07-10-2021, 05:14 PM   #2
Just follow the wires from the shore power plug to the circuit breakers. Should come up with something. Maybe the wire to the main circuit breaker has come loose, maybe the breaker has failed. Shouldn’t be too difficult.
Old 07-10-2021, 10:05 PM   #3
Tested breakers , all good. From what I tested no power getting in there. So time to trace from the cord up to the box
Thanks
Old 07-16-2021, 12:19 AM   #4
It was the power cord, even the Air conditioning works ,
Thanks everyone
Old 07-16-2021, 03:01 AM   #5
Thanks everyone
Welcome to the forum Falcon 90!
You have a nice basic older unit. So you have simplicity working for you, but age working against you. Having issues is normal. Glad this was an easy fix.
Old 07-16-2021, 07:02 PM   #6
Thanks , the mechanics seem well maintained. But the camper part they did not do much to
