Old 09-28-2018, 02:33 AM   #1
Default 2015 Roadtrek 190P
Looking for a way to remotely monitor solar input to the batteries, as well as the realtime draw, and status.. What are my option$ ? I have a roadtrek mtpp (mttp?) solar controller and 2 agm original equipment batteries.
bwolfsohn is offline   Reply With Quote
Old 09-28-2018, 02:41 AM   #2
The mid level Blue Sky Solar controllers with the Pro remote will give you all that. They are shunt based, so accurate current measurement, and the remote panel doubles as an battery monitor so you get all the instantaneous and cumulative data like any other monitor.
Old 09-28-2018, 03:07 AM   #3
Is your solar controller an EP Solar Tracer 3215RN?
Old 09-28-2018, 03:30 AM   #4
not sure.. itls the factory issue solar controller... ill check the specifics tomorrow..
Old 09-28-2018, 03:37 AM   #5
You may have to temporarily remove the 4 mounting screws in order to read the plate nomenclature. Copy it all down.
Is your 190 equipped with the underhood genny or the Onan?
Old 09-28-2018, 03:46 AM   #6
There're 10 best solar charge controllers for solar panel systems which can help you to protect the batteries from overcharge and discharge.
https://www.survivalrenewableenergy....e-controllers/
Monica998 is offline   Reply With Quote
Old 09-28-2018, 03:50 AM   #7
Onan . The solar is supposed to be an aftermarket unit but the solar controller is roadtrek
Old 09-29-2018, 02:43 AM   #8
Roadtrek doesn't build controllers. What does the controller label say?
Old 10-05-2018, 03:53 AM   #9
CE
MPPT Solar Charging Controller
This isn't from my 2015 190P, but another one that also has solar.. it looks to be the same controller as i have.
Trying to add the image.. it's on facebook, but doesn't show up here...
here's the link:
https://www.facebook.com/photo.php?f...type=3&theater
Old 10-05-2018, 04:20 AM   #10
CE
here's the link:
I steer away from facebook. Does your controller look anything like this:
http://voile.org/panneaux_solaires/Tracer-3215RN.pdf
Old 10-05-2018, 04:45 AM   #11
Yes, just like that.. only silver..
Old 10-05-2018, 05:14 AM   #12
OK, what you have is an EP Tracer Solar 3215RN. For the Etreks, it's a 3215BN which has an additional format for programming to suit lithium batteries. Since you are using AGMs, the RN version is what you have. You'll notice that it has an RJ45 port that is unoccupied. EP Solar makes a remote meter MT-5 that will provide you a display showing panel voltage and controller output.
Two things:
You can edit the controller program from this meter, but be cautious in doing so. Roadtrek programmed it for supporting AGMs.
The meter you need is an MT-5, not the MT-50 which supports the BN series controllers.
Operating manual:
https://solarlab.se/solpanel/datablad/display-mt5.pdf
Source:
https://www.rakuten.com/shop/ce-comp...EaAlEYEALw_wcB
User manual for your controller:
http://www.pvsolarchina.com/wp-conte...SER-MANUAL.pdf
Old 10-08-2018, 04:19 AM   #13
Is there any solar controllers can remotely monitor the solar input to all the batteries in the market, such as, the LiFePO4 batteries and so on?
