Old 06-23-2020, 07:27 AM   #1
roadbiker1's Avatar
Question 2008 2.8 Onan no charge from genset?
Fooling with Onan 2.8 Microlight problem, disconnected the coach battery bank, worked, reconnected, ran genset. Now genset does not charge the battery OR produce AC.
I did move the genset's control panel as part of the fooling and fought with the fuel filter... is the master reset breaker somewhere down in that dark hole below the control panel?
thanks
j
roadbiker1 is offline   Reply With Quote
Old 06-23-2020, 07:39 AM   #2
Do you have a Magnum Inverter or an Inverter thst is displaying HIGH A/C?
If so, the Regulator on your Onan needs to be replaced.
Or you simply have retrace your steps ...
Old 06-23-2020, 12:50 PM   #3
Wandering Wes's Avatar
Check the circuit breaker. (see attached)
Wandering Wes is offline   Reply With Quote
Old 06-23-2020, 07:29 PM   #4
roadbiker1's Avatar
thanks, my problem was ME hitting the circuit breaker while rummaging around the fuel filter, so your "Retrace" was right on! Thanks
Old 06-23-2020, 07:34 PM   #5
roadbiker1's Avatar
my gen is a KVFA maybe D model, slightly different with the "Let's make this totally
impossible to see" option on the breaker. Found it only by feel, reset and now back to
only the original weak fuel pump problem, so Progress! Thanks for getting me
looking in the right place. Cheers!
j
