Old 03-09-2019, 11:54 PM   #1
Default 2005 PW Excel converter location
Can anybody tell me where the converter is in a 2005 Pleasure-Way Excel TS? I'd like to add a charge wizard before I change out the battery. I'm also planning on adding an inverter with outlets; any advice would be appreciated. Thanks.
mrq3883 is offline   Reply With Quote
Old 03-10-2019, 04:24 PM   #2
I could have sworn a similar question was posted very recently, but I can't find my reply.
I have no knowledge of the location, but most rv electrics are grouped together for convenience of location and to save on wiring. Therefore, look for your fuse/breaker box and it is probably nearby, behind a panel or under a bed/seat cushion.
Be aware, that once you access this area, you will be in danger of electrical shock if plugged into 120V or if the inverter is on. Carefully test and ultimately unplug from 120v current and battery before working on or removing components.
Old 03-11-2019, 09:03 PM   #3
Found it! PW answered my email; it was under the sofa, behind a panel with 4 screws, accessed through the rear doors.
Old 04-06-2024, 03:00 AM   #4
Default 2005 pw
Got to the converter but how did you get it out?Got the first screw but there is one that seems impossible to gt .
mountainlion68 is offline   Reply With Quote
converter, pleasure-way
