Old 11-11-2016, 09:14 PM   #1
Default 2001 Pleasure Way TV antenna
Is there a antenna built into the van?
Susannlv is offline   Reply With Quote
Old 11-12-2016, 03:31 AM   #2
on many models a crank up antenna such as a winegard is used.
I have one on my 2006 PW
Old 11-13-2016, 08:48 PM   #3
On my 2005 PWay, the antenna is built within the roof (no visible external antenna). Assuming the same is true for your B, you should find a selector switch near/behind your TV which changes your coaxial cable input to your TV between the (roof) antenna and the external (campground) cable connector.
Les
LesM is offline   Reply With Quote
Old 11-14-2016, 01:41 AM   #4
Bruceper's Avatar
My antenna is built in as well, 1993 PWay.
