Old 02-10-2017, 03:42 AM   #1
Default 1999 170P Roadtrek ROCKER SWITCH
I have a 1999 170P Roadtrek and need the part number for the battery disconnect switch located in the info panel...it is in the lower right hand corner of the panel.It's a rocker type switch with 6 connector pins on the back of the switch.....Thanks
nikkor is offline   Reply With Quote
Old 02-11-2017, 01:39 PM   #2
You can start here. It is called a KIB monitor panel. Call 'em and tell them what you need.
KIB Monitor Panel Model K21X2 Repair / Installation Kits | pdxrvwholesale
